Le Deal du moment : -23%
199 €
 Tout sur les Big Tanks, 21 et 23 litres!
gadsby
VIPER SRT
Breizh Angel
Rico1700
kayamb
dedehp
Maxou
oliviervmax34
Vmax01
huch
yapasdep
lamousse
Pirate78
EVOL2B
bidalot
corse84
Tartopom
jean185
Abacar
aspic
budec
le steph
Langsuyar
nono22
jean jacques
minifred
Kristoff
tomira
V-Taz42
doc110
max-2.60
MotoArt
Jamie
Jean Jean
Manu68
vavoune
cissou
packo34
henri84
body30
hitechdan
jagmoto
xavier29
Clearmax
vmax40
jos 54
BLUMBY
gutenberg
extrasystole
YONYS
jerome
mike
vivikrikri
jag
millie
tab's
Didzam
Mc Fly
84 participants
Aller à la page : Précédent  1, 2, 3, 4, 5 ... 19 ... 34  Suivant
vavoune
vavoune
Style moto : 1700
Tout sur les Big Tanks, 21 et 23 litres! - Page 4 Empty
MessageSujet: Re: Tout sur les Big Tanks, 21 et 23 litres!   Tout sur les Big Tanks, 21 et 23 litres! - Page 4 EmptyVen 29 Mai 2009 - 17:21
savourez ce morceau d'anglais , IL ARRIVE notre cher réservoir de 21 litres tant attendu !!!!
"Well Folks, there are News and these are good News.
I received my Tank on Tuesday and begun to tear my Bike down in order to mount the new 21 Liter Tank. Florian sent me a a Prototype Type Tank with visual Sign of "hand allocating", but i don't care about that. Aslong as it fits as it should and takes maximum Filling, i'll be a very happy Camper. Nobody will see this except me and probably the Guy at Dealer while doing Maintenance. I ruined a Rivet and had to get a Replacement from the Dealer to begin mounting the Tank.
But Work kept constantly getting in the Way this Week. I'll probably won't get the Bike togehter this Weekend, so, it will be mid of next Week before i'll able to post my Findings. I mounted the Tank preliminary and placed the rear Sub Frame over it and everything lines up very good. I even was astonished about the dismounting of the stock Tank, it took me a bit more than of half the Time i calculated.
Once a good Description is made up, this Job could be performed from a mid skilled Wrench Head with a normal Set of metric Tools. It's really not that dramatic, easier than i thought. But needs a Set of extra Hands while placing the Subframe over the bigger Tank.
I'll keep you posted."
heu qui s'y colle pour la traduction ?
packo34
packo34
Style moto : Vmax 1700 & Ducati Multistra 1200 spéciale Packo
MessageSujet: Re: Tout sur les Big Tanks, 21 et 23 litres!   Tout sur les Big Tanks, 21 et 23 litres! - Page 4 EmptyVen 29 Mai 2009 - 17:50
Domage que cela ne soit qu un proto !! sad
a quand la fabrication en serie ??
je suis un 1 plein par jour lol!
Style moto : VMaxs 2900
MessageSujet: Re: Tout sur les Big Tanks, 21 et 23 litres!   Tout sur les Big Tanks, 21 et 23 litres! - Page 4 EmptyVen 29 Mai 2009 - 18:36
En gros, il dit que c'est un prototype mais que ça ne se voit pas une fois monté, qui fait 21 litres. Il n'a pas eu de difficultés pour le démontage ni pour le montage, sans outils particuliers. Il conseille d'être deux pour le montage.
Il postera ses impressions la semaine prochaine.
http://www.hope-togo.com
MessageSujet: Re: Tout sur les Big Tanks, 21 et 23 litres!   Tout sur les Big Tanks, 21 et 23 litres! - Page 4 EmptyVen 29 Mai 2009 - 20:17
Un bon ami germanique m'a traduit et résumé tout ton texte en 1 mot Vavoune :
Tanke!
MessageSujet: Re: Tout sur les Big Tanks, 21 et 23 litres!   Tout sur les Big Tanks, 21 et 23 litres! - Page 4 EmptyVen 29 Mai 2009 - 23:24
Ouais, mais ca vaut le coup d'attendre, on a que ca à faire en fait... Le gros boulot, c'est notre teuton qui s'y colle et c'est pas évident, vu qu'il faut que le chaudron soit homologué par la suite..
Citation à la c.n! Attendre est encore une occupation. C'est ne rien attendre qui est terrible.(Cesare Pavese)
MessageSujet: Re: Tout sur les Big Tanks, 21 et 23 litres!   Tout sur les Big Tanks, 21 et 23 litres! - Page 4 EmptySam 30 Mai 2009 - 18:25
Bon ce n'est pas encore cette année que je ferai la corse avec le maxou , tant pi c'est le tiger qui va si collé wink2
MessageSujet: Re: Tout sur les Big Tanks, 21 et 23 litres!   Tout sur les Big Tanks, 21 et 23 litres! - Page 4 EmptySam 30 Mai 2009 - 22:46
Combien vaux ce jolie réservoir...
mp merci
MessageSujet: Re: Tout sur les Big Tanks, 21 et 23 litres!   Tout sur les Big Tanks, 21 et 23 litres! - Page 4 EmptyDim 31 Mai 2009 - 18:07
Quelques info du tank :
Delivery out of the first Production Run until End of July shouldn't be a Problem.
Tank Sensor is in the Fuel Pump Assy and goes in the big front Hole on the upper Area. Filler Cap Assy goes in the other big Hole.
There are some minor Things to move or modifiy
- front bottom Plastic Shields needs to have cuts two Windows
- Seat Lock Cable Receptor need to be bent a bit to the Side
- two white Wire Connectors under the Seat need to be relocated
- several Rubber Pieces and the Overfill Hose go into the Cabinet
Production vers fin juillet
La jauge fonctionne
Deux caches plastiques antérieurs doivent être fenetrés
Le cable de déverouillage de la selle doit être déplacé
Deux connecteurs blancs sous la selle doivent être déplacés
Le trop plein et quelques pieces caoutchouc out.
MessageSujet: Re: Tout sur les Big Tanks, 21 et 23 litres!   Tout sur les Big Tanks, 21 et 23 litres! - Page 4 EmptyDim 31 Mai 2009 - 18:09
MessageSujet: Re: Tout sur les Big Tanks, 21 et 23 litres!   Tout sur les Big Tanks, 21 et 23 litres! - Page 4 EmptyDim 31 Mai 2009 - 19:00
le prix de la gourdasse c'est un secret d'état ou quoi ??
Si oui M.P. S.V.P.
Tout sur les Big Tanks, 21 et 23 litres! - Page 4 Vmax_c10
MessageSujet: Re: Tout sur les Big Tanks, 21 et 23 litres!   Tout sur les Big Tanks, 21 et 23 litres! - Page 4 EmptyDim 31 Mai 2009 - 19:03
Pour l'instant c'est tjs un proto le prix arrivera avec la mise en production donc très bientôt
mike
mike
Style moto : FJR et New VMAX
MessageSujet: Re: Tout sur les Big Tanks, 21 et 23 litres!   Tout sur les Big Tanks, 21 et 23 litres! - Page 4 EmptyMer 3 Juin 2009 - 22:43
J'en peux plus d'attendre ça j'ai la carte bleu qui chauffe et je ne demande meme pas le prix lol2
Clearmax
Clearmax
Style moto : MT01
MessageSujet: Re: Tout sur les Big Tanks, 21 et 23 litres!   Tout sur les Big Tanks, 21 et 23 litres! - Page 4 EmptyMer 3 Juin 2009 - 23:14
moi j'y vais la semaine prochaine ,je crois que je vais prevoir un ptit jerrican de 5 l supplementaires....j'ai un pote avec un top case,je crois qu'il va y avoir droit..... punish sarcasm mais ca reste tres chiant cette autonomie a la noix,j'ensuis toujours a 10 l de moyenne..... nul
MessageSujet: Re: Tout sur les Big Tanks, 21 et 23 litres!   Tout sur les Big Tanks, 21 et 23 litres! - Page 4 EmptyJeu 4 Juin 2009 - 5:20
Seulement tu dois rouler à l'économie, je plaisante mais perso en ville je suis plus proche des 14 que des 10 heat
MessageSujet: Re: Tout sur les Big Tanks, 21 et 23 litres!   Tout sur les Big Tanks, 21 et 23 litres! - Page 4 EmptyJeu 4 Juin 2009 - 5:28
+1
- parfois 15 litres ( cela dit :scratch: , je suis en rodage pour l'instant ) no !
MessageSujet: Re: Tout sur les Big Tanks, 21 et 23 litres!   Tout sur les Big Tanks, 21 et 23 litres! - Page 4 EmptyJeu 4 Juin 2009 - 5:47
Effectivement je précise que je n'ai roulé qu'en rodage depuis c'est un bras dans le plâtre mon timing était bon mon Vmax n'attend plus que moi
MessageSujet: Re: Tout sur les Big Tanks, 21 et 23 litres!   Tout sur les Big Tanks, 21 et 23 litres! - Page 4 EmptyJeu 4 Juin 2009 - 8:32
Et en mode patator, au bout de 80 bornes la réserve est allumée :ohmy:
packo34
packo34
MessageSujet: Re: Tout sur les Big Tanks, 21 et 23 litres!   Tout sur les Big Tanks, 21 et 23 litres! - Page 4 EmptyJeu 4 Juin 2009 - 9:05
C' est clair !! en ville entre 12 et 15 litres !!
body30
body30
Style moto : roadster
MessageSujet: Re: Tout sur les Big Tanks, 21 et 23 litres!   Tout sur les Big Tanks, 21 et 23 litres! - Page 4 EmptyJeu 4 Juin 2009 - 11:46
QUELQU'UN SAIT SI C POSSIBLE DE REDUIRE SA CONSO AVEC UN POWER COMMANDER OU AUTRE DANS UN MODE ECONOME QUI SERAIT DECONNECTABLE MEME EN ROULANT
MessageSujet: Re: Tout sur les Big Tanks, 21 et 23 litres!   Tout sur les Big Tanks, 21 et 23 litres! - Page 4 EmptyJeu 4 Juin 2009 - 11:55
Débranche 2 bougies crazy
packo34
packo34
MessageSujet: Re: Tout sur les Big Tanks, 21 et 23 litres!   Tout sur les Big Tanks, 21 et 23 litres! - Page 4 EmptyJeu 4 Juin 2009 - 12:06
ptdr lol2
Faut testé au gaz-oil hihihihi
Clearmax
Clearmax
Style moto : MT01
MessageSujet: Re: Tout sur les Big Tanks, 21 et 23 litres!   Tout sur les Big Tanks, 21 et 23 litres! - Page 4 EmptyJeu 4 Juin 2009 - 17:49
au fait ,y'en a t'il qui ont testé le 98?
MessageSujet: Re: Tout sur les Big Tanks, 21 et 23 litres!   Tout sur les Big Tanks, 21 et 23 litres! - Page 4 EmptyJeu 4 Juin 2009 - 18:42
Le changement est infime ride
Très peu perceptible nonono !
gutenberg
gutenberg
Style moto : roadster et routière
MessageSujet: Re: Tout sur les Big Tanks, 21 et 23 litres!   Tout sur les Big Tanks, 21 et 23 litres! - Page 4 EmptyLun 15 Juin 2009 - 18:51
Salut,
le sujet est un peu en panne... un nouveau post histoire de relancer.... il y a toujours pas de nouvelles du big réservoir ?
Pour l'autonomie, Je viens d'essayer l'éthanol, le calculateur semble capable de gérer au moins 60% de E85 (je me suis arrêté là...), démarrage correct, ralenti stable, bonne odeur d'alcool à l'échappement .... hum ! C'est parfumé... Le hic c'est que sur l'ordinateur en conso instantanée, ça fait quasiment 1 litre de plus qu'avec le 95... J'ai pas fait d'essai de conso mais le réservoir se vide encore plus vite.
Mais c'est normal, l'éthanol fourni moins d'énergie. Peut-être qu'en rajoutant un peu de toluène ????
MessageSujet: Re: Tout sur les Big Tanks, 21 et 23 litres!   Tout sur les Big Tanks, 21 et 23 litres! - Page 4 EmptyLun 15 Juin 2009 - 19:21
Tu veux augmenter l'indice d'octane du E85 avec du toluène ?
Augmentes l'indice d'octane du 98 ça va marcher plus fort encore wink3
Sinon tu as également l'essence pour modèle réduit c'est en général du Méthanol avec de 5 à 40% de Nitro (augmentation de la puissance et du régime moteur + diminution de la température moteur et de la consommation)
Mais attention à la casse aya
Il y a quelqu'un qui veut faire le Joe Bar Team et essayer pour nous donner ses sensations crazy
Page 4 sur 34Aller à la page : Précédent  1, 2, 3, 4, 5 ... 19 ... 34  Suivant
» 8 litres aux cents
» Tout sur le Flash de l'ECU.
» Nouvelle version du "Big tank"... A suivre
» Vmax 1994 : tourne sur 1 seul cylindre : a l'aide !
» Richesse c'est quoi air ou essence ou les deux!!!
